constant flow rate problem
I want a constant flow rate of 3L/min with 2 inputs, and I'm trying to figure out how to get my sliders to auto adjust based off one another.  If one slider is adjusted to .5L/min, I want the other to automatically balance out at 2.5L/min. How do I go about doing this?
(3,804 Views)
Hi Laplace,
a simple calculation like "3 - 0.5" would do the trick. Set the 2nd slider using it's local variable...
(3,802 Views)
Thats not quite what i'm looking for.  I'll try to explain a little better.  I have 2 sliders ranging from 0-10, how do I make it so that the value at slider A and value at slider B combined = 10.  If slider A is currently at 10, slider B adjusts to 0, if I move slider B to a value of 3, slider A adjusts to a value of 7. They need to balance according to the other sliders value.
(3,798 Views)
Accepted by topic author LaplaceT
Hi Laplace,
use an event structure to detect value changes of each slider. Adjust one slider according to value change of the other slider...
(3,794 Views)
Hi Laplace,
Gerd is right. Use the attached simple VI.
Tyler
Certified LabVIEW Architect
(3,792 Views)
Ok, got it! Thank you all for your help, i'm new to labview as you can probably tell.
(3,784 Views)
