constrained optmization
Hi everybody,
I have tried to use Labview for optImization as on Matlab, I have reached to use the VI unconstrained optmization but for my application I have to do a constrained nonlinear optimization problem. I've tried to see and use Constrained Nonlinear Optimization.vi, but I got stuck with defining the constrained. When I looked for some help, it only shows a template (labview\vi.lib\gmath\NumericalOptimization\cno_ob​jective function template.vit) which not giving much and real example.
For example I have function f(x) = –x1*x2*x3 and the constraint is x1 > 0; 1<x2<2 ;x3 <= 72. How to write the constraint function to be connected into Constrained Nonlinear Optimization.vi ? Can someone help me ?
If someone have a simple example....
Thank you.
Message 1 of 1
(3,092 Views)
