construct labview using visa
i have my computer connected and communicate with the data acquication
device. how do i construct front panel and diagram to control the
device using visa?
(2,722 Views)
Hi jason,
go to "Search the LabVIEW bookshelf" either from the LabVIEW help menu or from the start menu. There select the "LabVIEW Measurements Manual". There chapter 20 concerns about VISA.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,722 Views)
Hi Jason.
NI Has a "LabVIEW Instrument Control" class, it is only two days and will really get you up to speed on controlling instruments. ni.com/training
You'll probably want to download a certified plug and play driver for your instrument if one is available, it will make it a lot easier than parsing all of the data yourself. ni.com/downloads
If there is no instrument driver, then I suggest using the new I/O assistant in LabVIEW 7, it will simplify converting string data that you get from your instrument into something useful.
Are you connected to your device via serial or gpib?
(2,722 Views)
