context help
how can I update/modify "Context Help" window description of a VI?
I read the user manual (V.7.1), but I have not found much info.
(3,676 Views)
You can set the VI Description in the "Documentation" section of the VI Settings (Ctrl-I).  Then when you hover over that VI's icon on a diagram, you will see the description the Context Help window.
Hope this helps,
-D
(3,668 Views)
jjlee,
You posted this same question at http://forums.ni.com/ni/board/message?board.id=140&message.id=15875.
Please try to stop doing this duplicate posting. Pick a forum and do a single post.
(3,664 Views)
thanks for pointing out my mistake...
I did not realize that I made two of the same postings..
sorry about this...
(3,643 Views)
