continuable
Hi everyone!!
My question maybe is easy to response but I don't know how to do it... I did a subvi that converts a number into an array of bits (32 bits that represents one symbol). This array of bits go to another subVI that it does the OQPSK modulation. So, by the moment I just onlt transmit one symbol and it's ok because I see them in graphs. The next step for me is try to transmit more than one symbol, one after one. Any idea??
Attached my VI.
(3,417 Views)
How are the symbols generated? Will they be generated with a different period than the generation? If so I would make an array of the symbols that you need to convert and then run them through a fore loop when your program will allow. I would make one loop that generates the symbols and on the interpets the symbols.
Tim
GHSP
(3,406 Views)
You need to change the symbols controls to a 1D array, and you will put the two subvis in the picture in a for loop.  The for loop will run all the symbols in the array.
Kudos and Accepted as Solution are welcome!
(3,398 Views)
If I put a for loop contaning my 2 subvi, I have problems with the type of elements.......
(3,371 Views)
1. Right click on the output terminals of the for loop that look like a hollow squre
2. Select disable auto indexing
(3,346 Views)
If I put something like that, the graphs doesn't appear.
(3,327 Views)
Enable auto-indexing only on the terminal for your graph.
(3,302 Views)
