continues process
Your issue is that you are maintaining only one array through the shift registers, the raw data array.  The changed array is just being recalculated from the raw array for only the last 2 points on every iteration.
If you want the changed data to persist, then you will need to maintain your changed data array in another shift register.
Message 11 of 16
(1,389 Views)
Please help me to do that. I tried but cannot, again same mistake inside....Please if possible change my Vi and reply.
Thanks in advise!
Message 12 of 16
(1,384 Views)
Try e.g. this:
(You are still using way too much code! :D)
Message 13 of 16
(1,377 Views)
Thanks in advise!
Here is my modification to your previous code.
EDIT:   I see Altenbach's code now.  It is definitely much cleaner version.  I still don't completely understand what you are trying to do with your comparisons (and one time you talk about 0.1, another time 0.3) but his charts seem like a more reasonable end result.
Message Edited by Ravens Fan on 06-29-2008 11:09 PM
Message 14 of 16
(1,374 Views)
I realized that although I added the changed array shift register, the comparisons were to the previous raw data.  Here is the fix.  The results are more like Altenbach's, but his solution is still better.
Message 15 of 16
(1,368 Views)
Thank you everyone who helped Smiley Very Happy!
I used altenbach method, special thanks to you!
The problem solved!
Message 16 of 16
(1,359 Views)
