continuous V-I measurements for stability test
hello everyone,
I am a beginner at labview. I have to make a program to continuously measure the current and voltage using keysight B2900A for testing long term stability of solar cell and save data in a spreadsheet. Can anyone help me with it so that i can get a clear idea of how to do it
(2,422 Views)
Hi ujjwal,
Which is seen by the way you write LabVIEW…
Good advice: take those free courses offered in the Training section in the header of this LabVIEW board!
You need a loop.
You need some VIs (called device driver) to read values from your DAQ device: see here!
Use those "spreadsheet" functions in the file palette…
Show what you have done so far.
Explain where you get problems.
Or hire a developer!
(2,412 Views)
Thank you very much. I've followed the steps you told me and was able to do my work.
Can you help me with a timed sequence which executes the code on a logarithmic time scale, i.e. on 1 second, 10th second, 100th second, 1000 and so on.
(2,372 Views)
Hi ujjwal,
don't use a "timed sequence"!
Use a statemachine approach: a case structure inside a while loop. You need two states (from your description)
  • Wait (or WaitUntil)
  • Execute code
In the wait state you will wait your delay values (1s, 10s, 100s, 1000s), and in the execute case you execute your code…
Remark: it's not recommended to have just one wait of 100s. It's much better to call a wait of 1s 100 times…
(2,365 Views)
