continuous curve fitting
Hi everybody !
Here is my problem : I need to fit a erf function in my programm with the VI non linear curve fit . So I have set this VI up with static reference model in which I configured my erf function so far so good . That program works ..... for one acquitsition but for continuous acquisition the program doesn't work anymore  because of the non linear curve fit VI and tells me "the equation system cannot be solved because the input matrix is a singular one"
Do you guys have some idea about this ?
Thank you !
Message 1 of 13
(6,437 Views)
Without attached vi(s), we need a crystal ball 😄
Greetings from Germany
Henrik
LV since v3.1
Message 2 of 13
(6,405 Views)
Of course ! Sorry
On this picture you can see the part which cause some problem
Message 3 of 13
(6,400 Views)
Not only is there no picture, but pictures are not very helpful.  They show only a part of the code, they are sometimes hard to read, they cannot be "executed" or "tested" to see what is going on, and they drive me crazy (but that's probably my problem).
Please attach a VI, several VIs, or compress the folder containing your VI and attach the resulting .zip file.  We're happy to help, but please make our lives a little easier ...
Bob Schor
Message 4 of 13
(6,397 Views)
Ok I ; going to get the VI
Message 5 of 13
(6,397 Views)
Voilci le VI
Thanks for your help !
PS: Sorry but you won't be able to execute the VI because the treated data are from a
scope (via DAQx)
Message 6 of 13
(6,387 Views)
You also need to attach the model VI. It is not necessary to zip a single VI up before attaching.
How is the Y array on the the various calls? Does it ever contain unusual values (Inf, NaN, etc.). It is ever zero lenght? Are the values suddenly way outside the typical range?
Is the array of parameter guesses of the correct size? Your default is an empty array, which will definitely not work. Are the guess values reasonable? (Sign, order if magnitude, etc.). How does the model look when calculated from the guess? Any resemblance to the data?
Your VI has no loop, so what exactly is "continuous acquisition"? Please don't tell me you are using the "continuous run" button 😮
Message 7 of 13
(6,363 Views)
Hello altenbach thanks for your quick reply !
-The Y array only contains values form -1 to -10
-Firstly I thought the problem came from the fact that sometimes  the Y array  got a zero value but I put an offset (-1) to my data and the error is still here
-The array parameters guess is of correct size because I need four parameters to fit my experimental curve with a erf function
-I've made this study on qtiplot before and it gave the following parameters : -2,3,0,-2 . When I put those parameters in the pogram I got a nice erf function
-Yes I'm using the "continuous run button" :S why ?
PS: what do you mean by the model VI ? the diagramm ?
Message 8 of 13
(6,330 Views)
Your code contains a strictly typed static VI reference. Attach the model VI it refers to. It sows us how the error function is calculated and what the parameters are.
"continous run" is a debugging tool, not a way to run a VI normally.
Are the x values reasonable (just an integer ramp starting with zero). How big are the arrays? For positive X, the error function is positive, so why are your Y values all negative?
If you don't show us the model, we don't know how the parameters are defined and what their order is. What x-values did you use to calculate the error function for these parameters?
Message 9 of 13
(6,315 Views)
Here's the static model !
The purpose of this VI is to get a gaussian curve (vs time) deriving the erf function so the x arrays have been chosen to observe the gaussian curve and I can observ it during a few seconds and then the error occurs
Message 10 of 13
(6,294 Views)
