continuous data acquisition with extern clock on PCI 4474
I use labVIEW and a PCI 4474 (24 bits)to measure a tension in continuous with an extern clockbut there are not extern clock on this card. Can I use the trigger inputas extern clock ?
(2,574 Views)
In fact, there is no external clock on NI-4474. If you want to use it as trigger, you have to configure te device at each loop and it could be very slow.
The solution might be to use NI-4474 and NI-6602.
Isabelle J.
Isabelle
Ingénieur d'applications
National Instruments France
(2,574 Views)
