continuous plotting of 1D data
Hi
I would like to plot the data acquired from cRIO continously over time. Please find the attached screen shot of code and the RT launcher vi. In order to plot I'm acquiring the tick counts in micro seconds from FPGA and two analog inputs. With the present code the graph refreshes after each iteration. How could I make the data stay on screen for prescribed time of 5 minutes always.
Regards
Gurubaran
(2,866 Views)
Accepted by topic author Gurubaran
Use a shift register to keep track of the previous data, then append the new data to the old data.  You may also want to put a check in there to get a subset of the data if you have too much.  It is a common problem to append new data forever and forget about the fact that this means memory usage will grow forever too.
(2,862 Views)
Hi Hooovahh,
Thanks for helping out and reminding to include a check. I have incoprated and the code is working.
Regards
Gurubaran
(2,852 Views)
