Hi Dennis,
I have attached my Labview program and looks like I messed up how I link the shift register from
subVi to Main, so that no text stream comes out at all.
Could you give some hand to debug my issue?
Program info
Main LabView Vi name: MenuProto4_27
To run test,
1. Press "run" Labview Menu
2. Press "Start" button and for rest of pop up just press return key.
When open the block diagram,
You see a case block called, "Production" and underneath there is another case block, select case 0.
In that you will a subVI called, "openshort_test.vi" where I need to get the text stream to Main string indicator
called, "test status window".
Sorry for the messy program, I am not real labview program.
If you can help me out, I will really appreciate it.
Do
