contour plotting
Hi all,
I am new to Labview.
I would like to plot the contours shown in the attached png file.
I have the program that does the sweep of VA and VC (the axises). The contour will be the power/voltage from the photodiode, produced at each VA nad VC. I am not very sure on how to do this, as I have to monitor the contours real-time.
Any help?
Thanks!
Attached are the VA and VC sweep vi and the png file.
Message 1 of 27
(5,784 Views)
I came upon this example on 3D contour plotting and it suits my application well. However, I can't really understand the block diagram and am unable to edit it to get the result i want.
I have attached the vi below. (Output contour plott.vi)
There are 3 variables that i would like to have.
X-axis: VC
Y-axis: VA
Z-axis: Power Intensity
The Z-axis will be reading from an excel file that I have stored previously, whereas the x-axis and y-axis values are fixed, ranging from 0V to 20V with step of 0.01.
I am able to get the 0V to 20V with step of 0.01 using a while loop, but I would like to implement using a for loop.
The result that I would like to get will be shown in the power output.png.
Anyone can help?
Message 2 of 27
(5,731 Views)
I came up with the triggering sampling of DPO2024 from Tektronix.
Am not sure whether i have done it correctly.
I will be using the measured amplitude as the Z-axis in the contour plotting.
Anyone knows how to link them together?
Message 3 of 27
(5,718 Views)
Anyone knows how to plot using the 3D contour? I am not sure on the array part. kind of messy.. anyone can enlighten me?
Thanks alot!
Message 4 of 27
(5,702 Views)
To config the contour level, pick control shortcut menu->"3D Plot Properties" item->"Contour" page->"Contour" group.
To have X-Y projection, click the X-Y button on the right side of the control.
Message 5 of 27
(5,687 Views)
Dear hanrock,
Thanks for your reply.
I know how to wire the vi up. Just that when i run it, it doesnt get any value.
The attached vi is the updated one whereby i combined all together.
X-axis: VC (0V to 20V)
Y-axis: VA (0V to 20V)
Z-axis: Output voltage or power
I have to monitor the output real time, but I have lots of red dots in the block diagram.
Another concern is that I am using edge trigger (caused by the square waveform with duty cycle of 10%) to obtain the voltage at that particular time of trigger. I am not sure whether I used the correct method to implement this.
The array that I would like to get in the end so as to plot the 3d contour, will be something like this. So on and so for.
VC(x-axis) value 1
VC(x-axis) value 2
VA(y-axis) value 1
z-axis value 1
z-axis value 3
VA(y-axis) value 2
z-axis value 2
z-axis value 4
The main flow of the program will be to conduct the voltage sweep of VA and VC and measuring the output voltage(voltage of channel 1 of oscilloscope) at each rising edge trigger caused by square waveform, then obtaining the 3D contour plot of VA, VC and Output voltage.
So far, I ran the setup on the equipments.. only the voltage sweep is working. The graph plotting and voltage waveform has no results at all.
THanks!
Message 6 of 27
(5,683 Views)
Sorry i did some changes.
1 more concern is that I am afraid that my timing is wrong.
In the sense that by the time the triggering starts, my voltage sweep has already begun for a certain time. How do i synchorinise both of their start time, so that i can acquisite at the correct timing as intended?
Message 7 of 27
(5,679 Views)
VC(x-axis) value 1
VC(x-axis) value 2
VA(y-axis) value 1
z-axis value 1
z-axis value 3
VA(y-axis) value 2
z-axis value 2
z-axis value 4
THanks!
You are correct about the input. But I can not run your VI because of missing drivers VIs. Can you set a probe on the PlotHelper inputs and see if the input arrays are not empty? or attach the VI with one set of inputs as contant arrays.
Message 8 of 27
(5,675 Views)
Hi hanrock,
I realise that my x is an empty array.
I am kind of lost now. Ain't sure why it is passing an empty array...
Cheers
Message 9 of 27
(5,671 Views)
I did the following changes, and the empty array error is gone. But i still dont get an output on the Voltage waveform and the 3D contour graph.
Here is the updated vi,
Message 10 of 27
(5,667 Views)
