contrôler CMMS-ST-.-G2 via RS232
Bonjour,
Je dois commander un moteur pas à pas hybride à travers son contrôleur CMMS-ST-.-G2 avec labview via RS232 et je ne sais pas du tout comment m'y prendre.
Pouvez-vous m'éclairer un peu s'il vous plaît?
Merci d'avance.
Cdt.
(3,357 Views)
You use VISA Write to send commands and VISA Read to get days back. There are serial examples that come with LabVIEW that give you a starting point. I would recommend that you first use a terminal emulation program such as putty or MAX before writing any code. If the vendor provides a program, use that to verify cable and com settings. You need to attach code and the manual for detailed help.
(3,342 Views)
Thank you for your reponse.
Here is the manual of the motor controller FESTO I'm using.
I didn't write any code yet, I didn't know how to start, I was counting on your help.
Do you have any example of code that could inspire me?
(3,323 Views)
As Dennis wrote above, there are EXAMPLES that are included in LabVIEW.
Look at them.
(3,320 Views)
If you only have French documentation, perhaps you should not be using the English board.
(3,311 Views)
Hi Dennis,
Is there anyone as you have known already developed LabVIEW drivers via RS-232 for the controller by far?
Thanks!
(3,032 Views)
