control MS Power Point Viewer with labview
I would like to ask if it is possible to control the MS power point viewer application using the labview activeX object?
I also found the ppview32.exe application, which contains the msppt8vr.olb file, but I cannot upload it to labview.
I need to use labview to open a presentation and control the switching of slides.
Best Regards
(1,287 Views)
I tried this :
https://forums.ni.com/t5/Example-Code/Activating-and-Running-a-Slideshow-in-PowerPoint-from-LabVIEW/...
and it works. but only with the powerpoint application and not with the powerpoint viewer...
(1,223 Views)
