control adquisition with keyboard
Hello, I want to control my adquisition program with keyboard. First step I want for this is to get keyboard information while I'm adquiring. I have 2 version. In version 1 I get the keyboard information, but not allways, it depends on the moment I push keyboard buttons, and i'm adquiring data correctly. In version 2 I adquire keyboard information in any time, but I don't adquire correctly. What can I do?
Thaks.
Luz
Message 1 of 14
(5,571 Views)
hi,
Pls see attached vi as reference. Hope it helps 🙂
regards,
ian
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 2 of 14
(5,563 Views)
Hi Luz,
U can use ian fumg example as reference (thanx ian).
You can have problems mostly because of detecting several times the same key if you dont time it properly. I mean, if u check every 10miliseconds you can press a key for 100 ms and then detect 10 times de same caracter while it was only one.
I dont know how many controls you need to asign to keys but if you right click the mouse on a control and go to properties and then to "key navigation" option you can automatically asign key shorcuts to your controls. The only problem about that is that labview limits it to several caracters an its combinations with <ctrl> and <shift>. But if you only need a few controls (I think your program is one of them) that would be enough.
Jaime Cabrera
NI Applications Engineering
Jaime Cabrera
NI Applications Engineering Spain
Message 3 of 14
(5,547 Views)
Hi Jaime,
Thanks 🙂
Also, using dynamic runtime menu is another way of achieving the requirement.
[IFK_GUI_Runtime Menu Demo]
This demo vi show programmatically added menu items.
Queue event is used to demonstrate the menu items' execution
LabVIEW 7.0
Solution Prepared By,
Ian Fung, Koo
ian_fung@yahoo.com | Sg
Ian F
依恩与LabVIEW
Message 4 of 14
(5,541 Views)
Hola Jaime, si pulso botón derecho y propiedades no tengo la opción que comentas, "key navigation". ¿Qué me pasa?.
Gracias.
Luz
Message 5 of 14
(5,530 Views)
Hello Ian, and thank you very much. I can't understand your .vi. Can you simplify the program for me, please?. I only want, for example, that I press a key a led value is true. Can you help me?.Thanks.
Luz
Message 6 of 14
(5,529 Views)
Hello Ian and Jaime, I show you an example (using Ian example, thanks Ian) that what I don't know adquiring a signal with keyboard. If I push {Ctrl+t} I see that "Boolean 2" is on, but this event allways take place in iteration 0 of my signal, as I see in "Numeric". Why not, for example, in iteration 2562? I have  5000 in each iteration. Thanks.
Message 7 of 14
(5,521 Views)
Hi Luz,
I did a quick simulation by removing your DAQ VIs.
Pressing CTRL+"t" will activate "Boolean(SimulateGLobal)", which will in turn activate "Boolean 2" and causes an index value updated to your Numeric indicator. It is not always at 0 of the iteration.
My apologies if I have not captured your problem.
Ian F
依恩与LabVIEW
Message 8 of 14
(5,515 Views)
Hi luz,
key navigation is only for controls, not for indicators, so u can use key navigation for a button but not for a led.
Has no sense to activate an indicator. You can use the key navigation to a control that is connected to your indicator.
Jaime
Jaime Cabrera
Message 9 of 14
(5,514 Views)
Hello Jaime, if I right click the mouse on a control and go to properties I only have this options: appearance, operation and documentation, I don't find key navigation. What can I do?
Thanks.
Luz
Message 10 of 14
(5,507 Views)
