control and simulation - SMP
I am using a LabVIEW Real-Time 2012 and a Desktop RIO for some real-time
simulations. The CPU has four cores. I have a problem when I try to run
multiple control & simulation loops in parallel on different cores. I have
manually assigned different cores to the loops and they are running, but not at
the same time. I need them to have exactly the same simulation time,
synchronized to the CPU. Is this possible?
Thanks a lot!
Sinkva
(2,678 Views)
Hi Sinkva,
You can use notifiers or queues to 'trig' synchronous execution of loops, have a look at this white paper:
Application Design Patterns: Producer/Consumer
https://www.ni.com/en/support/documentation/supplemental/21/producer-consumer-architecture-in-labvie...
Make sure you are not entering the next iteration in the master loop until all slave loops have finished the current iteration (the slowest loop will set the timing).
Robert P-F
(2,592 Views)
