control lock-in amplifier EG&G 5104 with gpib-usb
Does anyone know how to control a old lock in amplifier EG&G  5104 with a gpib-usb?, i can comunicate with my pc, but the amplifier doesn't response my comands....
(3,128 Views)
Hi biazon,
So you can communicate, but the device doesn't respond? What kind of communication is this?
What have you tried so far?
The manual describes the commands your device expects, so send them and check for reactions of the device!
(3,105 Views)
this is the Labview project.  I'm having difficulty with GPIB/USB communication and Labview. Futhermore, this model does not have the option of frequency acquisition command like the SR830 model. I need to run a program that does frequency scanning. I would be grateful for some help.
(3,089 Views)
Hi biazon,
why do you talk about "GPIB/USB" and name this VI "GPIB sample" when the VI clearly uses a serial communication with your device???
Which difficulties do you have?
Use a different device when you need this option…
Or do the "frequency scanning" by setting parameters on your device programmatically. Reading the device manual will tell you the commands you need to use!
(3,082 Views)
