control more than one cpu
Do you get this message when you select 'Preview in Browser' or after you've saved it? If you are trying to connect from a client pc, you have to install the LabVIEW run-time engine on the client. You want to make sure that if you have a firewall, it is set to allow access.
There are a lot of little things that need to be setup correctly. I would recomend you do things one step at a time. First start the web server. Then do the preview before doing a save. After you have done a local save, then open your browser locally and open the saved page. When this is working, install the LabVIEW run-time on a client and try opening it in a browser there.
p.s. next time that you want to post an image, instead of embedding the image inside a .doc file, just attach the image. Just make sure you save the image as a jpg or png file.
Message Edited by Dennis Knutson on 05-28-2008 10:02 PM
Message 11 of 13
(758 Views)
I get the message when I select 'Preview in Browser' . Then I try to save it. But I still get the same message. I have try another 2 viewing mode Snapshot and Monitor. When I open the save page in my browser, the page is blank.
Why this happen?
Message 12 of 13
(752 Views)
The first thing I would try would be to turn of the windows firewall to see if that is blocking it.
Message 13 of 13
(726 Views)
