control of tank level
hi,i'm working on vi of "simulation -tank level-" and i need to use a colorize pump  "ex:green when it's activate and red when it's desactivate",thanks
(3,647 Views)
Accepted by topic author rikrak
So you will need to create a custom control.  This can just be a Boolean Indicator, make it a custom control, click the little wrench, then replace each state of the whatever picture you want.  You can do fancier controls with multiple states if needed withe a Ring.  Attached is one I did a while back.
(3,637 Views)
thanks, this is what i'm looking for
(3,582 Views)
Don't forget to mark their reply as a solution. :.)
I do this kind of thing all the time without custom controls, or at least what I think you're trying to do. Here's an example I put together. I'm including a png in case you can't open a LV2017 vi. I'm limited in which LV versions I have access to here...
______________________________________________________________________
The avatar is for the best weapon in any game ever. But nobody goes there anymore.
CLAD, LV2013, LV2015
(3,577 Views)
thank you very much
(3,554 Views)
