control position of popup dialog box
Is there a better method of positioning a popup dialog below a string control? - see attached (run parent.vi)
Can I obtain a Pane ref and a VI ref given a string control reference? so that I only need to pass the string ref
thanks
Al
(5,710 Views)
Accepted by topic author Al1234
You can use the "Owning VI" property for the string reference to get a reference to the parent VI. From that you can get the pane reference as well. Note: you should wire your error clusters. Errors can and do happen.
(5,693 Views)
If your VI has multiple panes (or just to be prepared), you can find, here  a VI that returns the pane of a control.
Ton
My LabVIEW Ideas
(5,683 Views)
Saverio, Thanks I've now removed the "this VI" ref - I completely missed that method in "OwningVI"
I'm using 8.5 is that why I don't see the "Panel" method in "OwningVI"? or are you doing some scripting wizardry?
(I removed all my error handling for clarity)
Ton, If I go to your link ( here   ) I don't see a download button...
(5,653 Views)
I've sent a message to Darren if he could re-add the file.
Ton
My LabVIEW Ideas
(5,649 Views)
It's not a method - it's a property. In the popup menu it's called "Front Panel". The default on the Property Node is to display only short names.
(5,626 Views)
Sorry - typing without my brain working.
Thanks, It works perfectly
(5,619 Views)
