control servo with a boolean
Hello.
I am trying to control a servo motor in LabView using a boolean switch. When pressing the switch the servo should go from 0 to 90 and when pressing it again it should go from 90 to 0.
I was able to move the servo using a numeric control, but i just cant figure out hot to control it with a simple on off switch?
I would really appreciate any help/idea! thank you
(2,954 Views)
Why don't you attach your VI where you were able to use the numeric control, then we can see what steps you need to do next to use a boolean switch.
(2,930 Views)
