control solenoid valve
I am a labview beginner. I try to use labview to control our gas permeation system. Firstly, labview acquire pressure data from PR4000 readout . When pressure is down to certain value then the data goes through NI 6501 I/O device then universal relay card to switch solenoid valve. Then labview coninue acquire pressure data from transducer .
I hope somebody can give me some advice for writing this program. Or what kind of existing VI programe can I use to modify it?
(2,966 Views)
Howdy MYLONG!
One of the best resources to find LabVIEW example programs is in the LabVIEW Example Finder.  You can access it in LabVIEW by going to Help>>Find Examples...
For examples on outputting data to the NI 6501 I would recommend looking in the Hardware Input and Output>>DAQmx>>Digital Generation folder.
If you are using serial communication to talk with your PR4000 then look in the Hardware Input and Output>>Serial folder for examples.
(2,924 Views)
thank you so much
(2,904 Views)
thank you so much
(2,902 Views)
