control the timing of LIN messages
I want to control a number of LEDs on a LIN bus.  I am using the USB-8476 to interface the network.  I need to send 6 messages to six LEDs to set their individual colors, and then send 6 new messages to make it appear the colors are moving down the line, one at a time.  I can't get the timing right, so I reduced the network to just two LEDs.  The messages are sent in a Timed Sequence of two frames, and that is inside a While Loop.  I have tried various combinations of Configured Time Sequence and Next Frame Timing, as well as various Wait Timers inside the While Loop, but I can't get anything remotely close to steady timing.
(3,124 Views)
Define "steady timing".
Assuming you are running this code on a Windows system there will always be some variability in timing because Windows is not a deterministic OS, and using timed loops won't help that...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,101 Views)
You may have better luck with an XNET LIN interface, which does onboard scheduing of message.
(3,096 Views)
Thanks for your replies.  I had some help from an AE at NI who explained I don't need the timed sequences unless I am using RT systems, so after scrapping all the timed sequences and loops, and just putting all the frames sends together with a small delay inside each case, everything works pretty good now.  Amazing how well this works once you see the correct way to code it!  Now if I can just figure out the build executable function, I will be successful.
(3,082 Views)
