control two servomotor and stop not together
Hi everybody,
It`s my first step on the NI forum. My apologize in advance if I`m not in the right section 🙂 but I think it`s the good one.
To resume my situation in two words, I`m making my intership for the end of my studies. I`m ingeneer in biochemestry and i have to work on labview.... so i`m not very good but i get by in this software (to be honest I like this).
Anyway,
With labview, I have to control two servomotor to open two gate but not together. I open the gate in the same time and then I have to close one and then the second. (or in the other sens).
My problem is that when I close the front gate and then the behind door everything it`s ok. But when I have to close the behind gate first I can`t close the other gate. And I have an error message (furthermore, arduino and Labview are desynchronised, it`s very boring)
I`m sure that my problem come from the end when i have to close the motor. I join my software and one picture.
I didn`t find others solutions to close the arduino card after everything. Maybe I can tr with one boucle while like in the beginning of my code. But I don`t want to add an other button.
Thank you a lot for your answer.
PS: I`m french and I`m Learning english.... so maybe it`s not perfect ^^
(3,450 Views)
I tried whit one boucle while.
(I was focus on my idea but I`m not oblige to put on button stop)
But it`s weird because everything works when I launch the software with the " higtlight execution" but without I have the same problem than before.
I don`t understand why.
Maxime
(3,428 Views)
Accepted by topic author Gerday.M
Hi Gerday,
Well, you burn your CPU using loops without wait states! Put some wait function in your loops. All of them!
Running a program as fast as possible is seldomly the best way…
The last loop (to the right) is pure nonsense! Use proper DATAFLOW provided by error cluster wires…
(3,419 Views)
I didn`t know about the wait states and that I was burning my CPU (But i`m not an informatician, so I don`t know exactly what it is ^^ but this week-end I will update myself)
Anyway with the wait states now everything works. ( by the way, is there a minimal for the wait states ?)
and about this sentences :
Use proper DATAFLOW provided by error cluster wires…"
I found nothing with the clusters. I can`t regroup the error wires or the pink wire..... Can I more information about this?
But thank you a lot for your answer.
I`m happy to succceed the control of my servomotors during this week.
Maxime
(3,393 Views)
