control windows application and enter field
Hi ,
I am trying to run a windows application (with labview 2009) and input required values .Attached is the example front panel of the application.The requirement is to input the values,as well as simulate some button presses.
Hope some one can help.
Alban Aruja
Application to be contolled
(2,734 Views)
Use Microsoft Spy++ to find the handle of the objects on the Window.
George Zou
(2,703 Views)
