controling ar drone using arduino
hello,
i am trying to control AR drone with arduino(using analog pins) i want to change the parameters in the control cluster but i cant get the connection properly
thanks for help:)
(2,689 Views)
You probably should add another posts with significantly more information. What parameters? Connection between what and what?
(2,669 Views)
