controling external software
Hi All,
I am attempting to create a VI to take some measurments from some test equipment that are all connected via GPIB ports. All this is okay but to get a signal/measurment I have to set on the driver of the unit under test to run/on.
Is it possible to create a VI within LabView that will write to the driver and set the UUT to run/on so that there is as little as possible human intervention?
Hope you can help, any example VI's will be brill.
C
(2,680 Views)
The answer depends on the hardware.
Check the manula for the widget you are using.
Ben
(2,677 Views)
