02-08-2006 09:14 AM
I'm beginner programmer in the labview environment, can u help me to control hp impedance analyzer by PC using labview & Gpib .. More details please
regards
02-08-2006 09:19 AM
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
02-12-2006 08:14 AM
hi TiTou
labview version is 7
hp impedance analyzer 4192A ( low frequancy impedance analyzer )
the requiread measuread paramteres are
electrical impedance ( magnitude - phase ) over the frequency band
reactance ( capacitance - inductance ) over the frequency band as well as the quality factor .
02-13-2006 03:55 PM
12-11-2006 09:18 AM
12-11-2006
09:33 AM
- last edited on
05-29-2025
08:54 AM
by
Content Cleaner
VISA ships with LabVIEW. It will be on your drivers CD along with NI-GPIB. If you did a full install, you may already have VISA. Open MAX (Measurement & Automation Explorer) and expand the software listing. You can also download any version you want from here. Version 4.0 is the latest and I would recomend you download that. VISA is an API that you use for the amjority of instrument communication. It works with serial, GPIB, Ethernet, USB, VXI, PXI instruments. Instead of using a different low level driver for each, you only have to learn and use one. This makes drivers more portable as there are few changes you have to make to the driver to work with any of them. There could be any number of reasons why your program doesn't work. You could have the wrong address or could be writing the command incorrectly. My suggestion wuld be to install VISA and try the driver. If you have problem using the driver, post back with any error codes that might be generated.
I just looked at the 7.x version of the driver. It doesn't use VISA so you should be able to use the driver as is. Just make sure the address matches what your instrument is set to.
Message Edited by Dennis Knutson on 12-11-2006 08:36 AM
11-26-2008 07:10 AM - edited 11-26-2008 07:13 AM
