controling html form
I have a html form compounds in two fields first and last name and a sibmit button, how can I control it in labview
(2,644 Views)
If you are asking about controlling the submit button, you will need to do a couple things.  First, obtain a reference to the submit button, by determining the name of the button from the webpage.  Then you would need to call a 'submit' method of that referenced button.
See the thread here for more ideas on how to do this:http://forums.ni.com/t5/LabVIEW/How-to-fill-out-and-submit-a-web-form-using-LabVIEW/td-p/289527
(2,603 Views)
