controlling an event structure
How do I run run the event loop more than once while the while loop continues?
(2,728 Views)
exo,
you definetly have to take a look here.
hope this helps,
Norbert B.
Norbert
Expert: Geometry
(2,717 Views)
Anything you want to run more than once has to be inside a while loop. Add a value change event for the stop button and you can have both while loops stop at the same time.
(2,713 Views)
