controlling mouse using patterns
Hello dear Experts!
Can someone please replicate the following VI that this guy creates in the following YouTube link?
https://www.youtube.com/watch?v=dtSN0MHRLWk
I have limited experience with LabView and am working on a similar project. Please help. Thank you in advance!
(3,766 Views)
You won't find anybody here who will do your work for you. If you are working on a similar project and have specific questions then we can help you with those. You will also learn a lot more by doing it yourself.
_____________________________
- Cheers, Ed
(3,730 Views)
Very well, Ed.
I will provide a bit more detail on our project.  Using Vision Builder, along with SmartCam, we have been able to have the camera track one's eyes.  We then will share the variables of pixel position (or vector magnitude and angle from eye to center point within ROI we set) to LabView.  We would like to have the cursor update to the said position and have the VI run continuously, so as to allow one to use the cursor with their eye movement.  Furthermore, clicking is also something we would like to implement, using conditional logic.  Basically, help is needed with linking the coordinates of the detected object with the mouse cursor.  Am assuming it would be possible to link the variables to SetCursorPos.vi?
Thank you for your help.Smiley Happy
(3,717 Views)
Accepted by topic author belyileha
"Am assuming it would be possible to link the variables to SetCursorPos.vi?"- to answer your only question so far, yes it's possible. Just wire the variables to the input, bundling them into the correct format if necessary.
(3,705 Views)
check this link it contains the necessary info plus the code which may help you.
A Webcam-based Point-of-gaze Tracking System......
https://decibel.ni.com/content/docs/DOC-29768
(3,686 Views)
