08-16-2006 06:13 AM
08-16-2006 08:31 AM
08-17-2006
06:01 AM
- last edited on
07-29-2026
09:04 AM
by
Content Cleaner
Hi Sri,
Thanks for posting on the NI forums.
As gwd noted this device has an RS-232 port and indeed does have a GPIB interface, but no ethernet port as per the page three of the 33250A's spec sheet (link below). This means that the instrument can be controlled from your desktop PC via an RS-232 (COM) port (one port per instrument), or via a GPIB card in your PC. As GPIB is a 'multidrop' communication method you will only need one GPIB card to control both instruments in this case.
http://cp.literature.agilent.com/litweb/pdf/5968-8807EN.pdf
I assume you are programming in LabVIEW as this post in the LabVIEW section. There is an instrument driver provided for the LabVIEW environment on the NI website which should make it easier to control your instrument(s) (see link below).
http://sine.ni.com/apps/we/niid_web_display.drv_results?p_app_area=&p_man=agilent&p_keywords=33250&p_inst_type=signalGenerator&p_env=&p_drv_type=plugandplay&p_int =
I hope this helps. all the best,
Rob
08-17-2006 06:36 AM
08-17-2006
08:09 AM
- last edited on
07-29-2026
09:04 AM
by
Content Cleaner
Hi there Sri,
You will need one GPIB-USB-HS and three cables to conntect between the GPIB-USB-HS device and your instruments (see link below).
https://www.ni.com/en/shop/hardware/catalog/cables#product_name=118312
Please see the attached JPEG for the physical layout of a typical GPIB system.
A typical GPIB system consists of a controller (your PC-based GPIB-USB-HS) and and several talkers/listeners (your GPIB instruments). In this case you will need to open three sessions in your LabVIEW code (one to each of your instruments) then action the configurations/measurements etc for each of them individually.
I hope this helps. All the best,
Rob
08-17-2006 11:16 AM
