controlling scale of a graph
Hello
I took measurements from an instrument via the GPIB port and I display them on a graph. the problem is that every time I adjust the scale of the graph to display a good avour. is there a other way to control the scales of my graph !
tkx for the help
(3,465 Views)
You can run "autoscale once" using a property node of the graph. The autoscale will be run once and after that you will have full control over scales.
(3,461 Views)
thank you for your replay. Can you explain to me more by an example ??
(3,458 Views)
Hit the "Generate Random Numbers" at different times and see the Y autoscaling.
(3,452 Views)
Thank you again
the problem is that I want to control the x-axis not the y-axis !!
(3,446 Views)
Accepted by topic author za3im_ensa
Right click on X axis of graph and uncheck "Autoscale". Now, right click on the property node and go to Select Property. Find X Scale and select ScaleFit.
(3,442 Views)
