Hi Steve,
I've attached a simple example... try to open this!
You should attach a property nody to the controls output, then you can select "currentPosition"
Good luck!
PS. I lately got an error saying my directX driver was outdated?? i use version 11... Anyway, i installed "elecard" media and streaming pack and after that the k-lite full codec, then my h.264 mpegs worked again, wierd though. It hasn't to do much with your problem, but maybe you have a similar problem with the directX thingy!
