conver exe to vi
Sir
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 16
(1,161 Views)
@paul_a_cardinale wrote:
I don't remember.  Try my old VI extractor.  I wrote it in LV 10.  Probably still works.
So this is intersting.  This maybe a topic for another post, but where in the world did you get Open.VI From Buffer Invoke Node?  I understand what private methods are, and the "secret" key so I turned them on but I couldn't find Open.VI From Buffer.  So I ask where did this come from if it is not from the normal means of finding private methods?
EDIT: Okay so I think this is a deprecated method which is why it doesn't show up in the list.
EDIT2: Okay just one more edit.  So I ran this on an EXE I made without debugging turned on, and it couldn't save the VI, it died on the Save Instrument function.  But before that everything was fine, so I replaced the Open VI From Buffer, and the Save Instrument, with a Write to Binary File (with a False on Prepend String size).  This resulted in me pulling out all of my VIs from my EXE.  I could then call these VIs in this version of LabVIEW only (as expected), and I only have front panels to VIs that are being shown in the EXE (again expected).
Quite interesting stuff.  The argument could be made that this is just as safe as a DLL, because there is no looking the source, and no way to even know how the VIs work or what they will do, other than the VI name which helps if you name your VIs appropriatly.  As a recovery tool this is nice, as a hacking tool it is not.  Thanks for sharing it.
Message 12 of 16
(1,142 Views)
I think I originally got the Open.VI From Buffer from LV 7 with scripting & special features turned on.
These days I have a utility that lets me specify the method of an invoke node by typing in the name.
Note that if in your builder you uncheck "Remove front panel" and "Remove block diagram" for all VIs, you will be able to extract the complete VIs from the .exe.
Message 13 of 16
(1,122 Views)
Another thing I observed with your VI Extractor is it only extracts VI (which I should have guessed).  I extracted all the VIs in an application but I couldn't run the top level VI because it was missing some class files that weren't extracted.
Message 14 of 16
(1,104 Views)
(I hate it when people reply to them selves)
So I can get a reference to the lvclass by using the Property Node on the VI getting the Library.  I can then get the path and name of this library but the "Save to Buffer", "Save", "Save For Previous", "Save a Copy", and "Save.Target Library" all will not work in the Run-Time engine.  So unless someone else has found a way you won't be able to extract the lvclass file from an EXE.
Message 15 of 16
(1,092 Views)
Well, it sorta worked. All the .ctl files were there and a global vi (no block diagram). Lots of the vis would not load because there was no block diagram so they must not be embedded. I was surprise to see as many files as I did though. Enough to get me started with editing some old code. Thanks.
Message 16 of 16
(1,078 Views)
