conversion of a binary data stream to decimal numbers
Hi
I am having great difficult working out how to convert my binary data stream to decimal numbers.
The data I am reading back is in the format of a binary string, starting with the Most Significant Bit (MSB) of the first word, then the corresponding Least Significant Bit (LSB), where a word is two bytes long. A carriage return indicates message termination.  The return message starts with ‘bin,’ followed by the number of bytes requested. No delimiters are used to separate the data, but a carriage return is appended onto the end of the data.
bin,<first word msb><first word lsb>...<last word lsb><CR>
e.g. bin,$ro¬z1;@*...etc
Does anybody know of any examaple vi that can help me convert this data from binary to decimal numbers?
Many Thanks
Ash
(4,001 Views)
Ash
Can you post your VI with example data?
thanks
David
(3,991 Views)
Hi Ashley,
after getting the string you can strip the first 4 characters. After this try a typecasting to array of U16. If the numbers are not correct, you can add a swap bytes operation to the resulting array.
Message Edited by GerdW on 09-13-2006 02:46 PM
(3,988 Views)
Hi David
Attached is my vi
This is the data format:
bin,E€H€I€I€I€H€I€G€H€HI€I€K€I€I€I€I€I€H€II€I€H€I€I€I€K€I€I€HI€I€I€H€I€K€I€I€J€KI€K€I€I€I€H€I etc...... <cr>
I take the data in chunks in a while loop which terminates when there are no bytes left at the port.
I hope this explains the probelm beter.  I am going to try Gerds suggestion and see how I get on.
Many thanks
Ash
(3,966 Views)
Gerd, what is the name of the first function that you used to remove the first 4 characters... I am searching high and cannot find it 😞
edit:
10 mins of searching.. I post this question and find the string subset function 30 seconds later.......
Message Edited by labstew on 04-26-2007 02:49 PM
(3,831 Views)
