conversion software from labview 4.0. to labview 8.5.1
We have some programs written in Labview 4 that we need to run on Labview 8.5. In the Labview upgrade notes, I see that I have to contact NI for conversion software. How do I access this conversion software?
(2,435 Views)
This has been asked now for umpteen no. of times by many people.
What you can do is either contact NI directly for conversion or post your code here (if they are relatively small) so that someone will convert it for you. FYI, LV 8.5 & above will open VIs only upto version 6.0. It wont open codes developed in previous versions below than that. So, your original older codes need to be opened in some intermediatory LV version between these two, so that they can be opened in LV 8.5.1 or above.
- Partha ( CLD until Oct 2027 🙂 )
(2,425 Views)
