convert 1 element cluster to 3 element
I have a problem in my vi .
I want to convert from cluster of 1 element to 3 elements
I will appreciate if anyone can help
Saud
(2,574 Views)
The sink is a waveform data type, which it tells you in the Context Help window. Did you read the LabVIEW Help? You need to use the Build Waveform function (in the Waveform palette) to create this data type. From your screenshot it appears you have just the Y array. You can use the default value for t0 and deltaT, or set values as needed.
(2,566 Views)
