convert 1d array to scalar
HelP:
I obtain analog inputs using AI sample channel.VI inside a while loop. The inputs are compared with a number, the results(T/F) will be displayed. Is there any way that I can use the boolean indicator instead of boolean array?
Thanks a lot
(4,260 Views)
Did you want it an array of indicators, or one indicator to represent an
array of values?
"connector" wrote in message
news:506500000008000000B1690000-1031838699000@exchange.ni.com...
> HelP:
> Thanks a lot
(4,260 Views)
Thanks for your reply. I want one indicator to represent an array of values.
(4,260 Views)
On the boolean palette, use the
"Or array Elements"
Ben
(4,260 Views)
