Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
convert 2d array to 1d array without using shift registers and build array
Gops
Member
05-31-2003
12:27 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
hi
I want to convert 2d array to 1d array without using shift registers and build array. Basically, i want to reduce the overhead involved in using the build array.
1
Kudo
Message
1
of 4
(3,264 Views)
Reply
Re: convert 2d array to 1d array without using shift registers and build array
paul_s
Member
05-31-2003
06:00 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Have you tried "reshape array" function?
1
Kudo
Message
2
of 4
(3,263 Views)
Reply
Gops
Member
Author
05-31-2003
06:25 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi
Thanks for the suggesstion, i tried it and it works as i expected.
bye
1
Kudo
Message
3
of 4
(3,263 Views)
Reply
Dennis_Knutson
Knight of NI
06-01-2003
02:21 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Index Array will also slice out either a row or column.
0
Kudos
Message
4
of 4
(3,263 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
