convert 5.1 file to 8.6
Hello all !!
I've got a little problem.
Since i've update my labview to 8.6 i can't convert files from 5.1.... 😕
Is it possible for someone to convert the file linked for me ?
Thanks by advance !
Pierro
Message Edité par darkpeter le 04-21-2009 12:09 PM
(2,822 Views)
Attached is the VI in 8.2, but I don't think it's going to help since there are several subVI that are missing, including a global variable.
Message Edited by smercurio_fc on 04-21-2009 01:11 PM
(2,802 Views)
Hello darkpeter,
As smercurio_fc said some subVIs are missing. You should have a look at this knowledgebase entry and this help file which explains in a table all possible combinations. Here is attached the VI in 8.6.
Message Edité par Steve Mohamed le 04-23-2009 09:47 AM
Steve M.
(2,774 Views)
