convert 5 number manually to array
Hi every one ,
I want to press 5 number by slider manually to array .
can you help me , how i do it .
thanks
Message 1 of 15
(6,555 Views)
Hi Himmel,
use the BuildArray function to build an array…
You know this is pretty basic LabVIEW stuff explained in the beginner tutorials?
Message 2 of 15
(6,551 Views)
can you provide more details
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 3 of 15
(6,550 Views)
I know but every time I want a number and  I want the numbers  press in each element in array .
Message 4 of 15
(6,547 Views)
I want to convert  5 different  numbers   to array . but I have just 1 control (slider ) .
Message 5 of 15
(6,541 Views)
Hi Himmel,
and how do you want to put 5 values into an array using just one slider control?
Message 6 of 15
(6,520 Views)
and start my problem from hier .  slider simulates as a Sensor . I want sensor sends the value as a number and after 5 number are sent  . they  are creat as a array . I want it by for loop . but I can`t .
Message 7 of 15
(6,509 Views)
Loop is already a good start.
Next key words you should look up:
- Shiftregister
- Build Array function
Norbert
Norbert
Expert: Geometry
Message 8 of 15
(6,502 Views)
Try to post your original code which you are trying?
Hope your Requirment looks simple but its not providing clear understanding.
Message 9 of 15
(6,497 Views)
this is my project . I marked  the PART, that i can`t solve.
Message 10 of 15
(6,489 Views)
