convert 64bit UTC time since 1 jan 1601 to current time labview 7.1
I need to convert a 64 bit UTC time 100-nanosecond intervals since january 1, 1601 to current time. I'm running LV7.1 on WinXP. I cannot identify any calls from windows dll's. I figured there would be something in there. Any format string, or what-ever, will do. I have a file with 8 bytes that containe the time. Help!
Message Edited by _K_ on 01-25-2008 09:32 AM
(8,661 Views)
Hi _K_,
      The conversion doesn't look too difficult, in fact, here's a start.  I really wanted to test this, but an hour of searching has netted me no example year-1600-based, U64 timestamps to test with.  Keywords seem to be "ASF" and GPS.  Perhaps you would supply a few strings - in whatever the native format is (i.e. Hex, binary) - a file would be ideal! (?)
There are two VIs, one to convert the U64 (bin-string) int to EXT, the other to convert the EXT (centi-nanoseconds since 1600) to LabVIEW seconds since Jan 1, 1901.
It wouldn't surprise me if the ToSecSince1901 VI needs tweaking, though it should be close.
... then again, tst has a habit of pointing out already "known" solutions - from here on this forum, or on OpenG - that may be better.
Cheers!
Message Edited by tbd on 01-26-2008 05:29 PM
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(8,627 Views)
... adjusted for base-year = 1601 (instead of 1600)
(8,610 Views)
Thanks! This should get me going. It seems to work great at 30hz. I don't have any data at higher freq. to test yet. I hope this time sample is what you were wanting. Let me know if you need more.
Message Edited by _K_ on 01-26-2008 11:27 PM
(8,603 Views)
It seems to work great at 30hz...
If it's been validated with real-time data, Excellent!  The posted-data looks about a year old and without knowing what the times were actually supposed to be, I wouldn't have "warm-fuzzys" until I'd validated one U64-to-seconds conversion against known data (scrutinizing the correctness of the conversion - year, mo, day, etc - down to the second - even milliseconds if the known data provides it.)
I expect you've already done this, but just want to make sure.  Otherwise, if it works for one U64. then it should work for all
Cheers!
(8,592 Views)
The data is from Feb, 6 2007. There is a file reference time of "2/6/2007 12:45:25.900" in the header of the data.
This data as you know has 2/5/2007 12:45:43.***. Unfortunately I have no way to verify the time code receiver settings versus the PC time setting from the time of the recording. My immediate concern is to get the data into a form that I can get my program running. I thought there might be some adjustment needed to correct time. I still need to test at 500+hz data rate. Lots to do, but I'm getting off and running. I hope to have an opportunity soon to examine data with a known UTC time. I will post the results. You have been a great help, and I wish I had an answer for you now.
(8,583 Views)
Hi _K_,
This is good info. - it implied an error in the value of 110668 as representing the day-count from 1601 to (but not including) 1904, and the following math justifies a correction to 110667.  Since this number is subtracted from the input during the conversion, it should improve things. Smiley Wink
'Dunno whether to be worried about the difference in seconds; it could be the file was written shortly after the data was collected.  Possibly, the PC's timebase differs from the data-source's timebase.  While the "seconds" part of the calc is very straight-forward, probably still need to validate it once.
Re: 500Hz data-rate, doubt this calc will slow you down, though if it comes to squeezing cpu-cycles out of a diagram, you might post this as a new thread with that as the subject.  It sounds like "we're" collecting data in a loop(?)   First questions might be: what are the external dependencies - what kind of IO is performed with what kind of hardware - and is there a [loop] timing-precision requirement?
Cheers.
Day-count calculation (days from 1601 to 1904)
days: "normal" 4 years    =   1461 (  366 +  3*365  =  1461 ) 1st year is leap-year
days: "normal" century    =  36524 ( 1460 + 24*1461 = 29220 ) 1st quad-year isn't a leap
      From first day of Start year
        |     To (but not including) first day of End year
      Start   End
days: 1600 - 1700 =  36525 (1600 WAS a leap year, by 400 year exception)
days: 1700 - 1800 =  36524
days: 1800 - 1900 =  36524
days: 1900 - 1904 =   1460 (1900 was NOT a leap-year, by 100 year exception)
days: 1600 - 1904   111033
days: 1600 - 1601     -366 (1600 WAS a leap-year, by 400 year exception)
days: 1601 - 1904   110667
(8,571 Views)
