convert Agilent 34972A command to labview program
I'm using labview to remote control Agilent 34972A.
i need to read from one channel at a higher frequency,and write the result in a file. I think the following command would do that, but I couldn't make it work in labview program.
CONF:RES  70000,1(@101)
ROUT:SCAN(@101)
TRIG:COUN 1000
INIT
FETC
I attached the program that I'm using right now to get data from different channels with lower frequency.
Thanks.
(3,906 Views)
It was suggested at http://forums.ni.com/t5/Signal-Conditioning/reading-from-one-channel-without-mechanical-opening-and-... that you use the monitor function but I guess you didn't read that or bother to try.
(3,901 Views)
I did try to find the subVI in the library, but I didn't find it, even though I googled it. Then I went on with another way, using the command from Agilent.
Could you explain more to me, what's driver and the monitor function?
(3,870 Views)
It's called Monitor.vi and its in the instrument driver you download when you go to Help> Find instrument Drivers.
(3,861 Views)
