convert KI DAQ libraries from LabView 5.0 to 2009
Hello everybody!
I have in the following zip containing the 4 libraries that can control my PCI 3102 acquisition card from Keithley.
Unfortunately, these libraries were implemented in LabView 5.0 and I have the new 2009.
I saw on other posts that the easiest solution is to ask if someone has intermediate version of LabView (like 8.0 or 8.2, preferably 8.2.1 according to the FAQ  http://zone.ni.com/devzone/cda/tut/p/id/8387). In these versions, the libraries will be opened without any problem, and you could just save them in the earlier release so that I can open them in 2009.
It could be very nice if one of you could do it so that I can avoid installing LabView temporary version just to convert these 4 libraries!
Thanks in advance for the help. Smiley Wink
(2,529 Views)
Well, the easiest thing to do would probably be to get up to date code from Keithley.
Here they are but you did not include the low level functions so you would need to convert those or get them from Keithley.
(2,517 Views)
