convert U32 array to binary array
I am using Labview 7.1 . Now I have an array storing a lot of U32 numbers. I wanna convert the U32 number into 32 bits binary numbers and send each bit to a new array. And then I can write the new array to a text file.
For example I have an array with 2 elements,1 and 1. I need convert each 1 into 100000000000000000000000000000000 and save this binary in a new array . The new array will be 64 elements long.
Thanks.
(6,184 Views)
Here is an example of one way to do this.
Lynn
(6,173 Views)
Hi Johnsold:
I think you just misunderstand what i want.
I need the 100000000000000000000000000000000,each of the binary number is an element of the new array. not all these binay in one element.
can you do that ?
(6,157 Views)
Hi Lightmidd,
      do you mean like this?
Message Edited by Dynamik on 12-06-2005 01:38 AM
When they give imbeciles handicap-parking, I won't have so far to walk!
(6,151 Views)
I think the attached will do what you need (LabVIEW 7.0).
Message Edited by altenbach on 12-06-2005 12:00 AM
(6,143 Views)
Hello lightmidd...,
why not use the "Convert number to boolean array" from conversion palette? If you need numbers instead of booleans use the "boolean to 0/1" afterwards.
(6,141 Views)
doh!Smiley Very Happy
(6,135 Views)
