convert .VI file to Simulink model
I have a motor task that tests Fitts' Law programmed in LabView. Is there a way to convert the .VI file to a simulink model? The purpose for the conversion is to run the task on a Kinarm robot (http://bkintechnologies.com/) which only runs simulink models through its own software (Dexterit-E). I've seen many posts doing the opposite - .mdl to .VI conversions and I was wondering if the reverse is possible.
(3,048 Views)
You'd probably want to try mathworks' site to see what they can do.  People here generally are working to get things working with LabVIEW.
(3,029 Views)
