convert Word document into HTML document
I require an idea to accomplish the conversion of a .doc (word file) to .html (HTML file) in LabVIEW.
I am working on a project in which i am having reports being generated after each test case execution.
The data after the each test is meant to be appended in the corresponding report.
I just want to convert the .doc file  to .html file for only display purpose as this is a requirement.
I dont want to use any kind of converters in this.
I have to do some calculations and modifications in the report before saving it,  that's why i am thinking in this way as i had come to know that this is possible in LabVIEW.
Can someone help me in this regard.
Thanks & Regards,
Samriddh Sarbalhi
(5,064 Views)
Since you already create word docs, you would have to use the "Save as" method of the MS Word API to save the loaded word formatted doc into a html formatted one.
André (CLA, CLED)
(5,060 Views)
Can i do this programatically using LabVIEW VI's.
Thanks & Regards,
Samriddh Sarbalhi
(5,046 Views)
Worst case you woud have to create your own set of VI's to handle the task implementing the functions of the MS Word API.
André (CLA, CLED)
(5,040 Views)
As noted, you need to access the Microsoft Word ActiveX server using the LabVIEW ActiveX functions. There are several examples that ship with LabVIEW (Help -> Find Examples) on how to use ActiveX. You can also search the NI site.
(5,021 Views)
here are some c# source codes on how to convert word to html for you. hope this can help you on your project.
(4,202 Views)
