convert a hexadecimal array to signed integer
I've created a hexadecimal array. I need to convert it to signed integer
For example if I input 'ff48' into the array, I should get -184 as the output.
I tried creating a local variable from the Hexadecimal input and changing the representation to decimal, but then 'ff48' is being converting to unsigned integer, i.e., 65352.
Is there a way to do it?
I've also attached what I've done up till now.
Thanks.
(3,935 Views)
Accepted by topic author sarwatsarfaraz
Hi sarwat,
No, you did not create an array. You placed a default scalar control on your frontpanel!
No, you don't need to convert to "signed integer", it already is a signed integer as you set the I32 datatype!
Set the datatype for both frontpanel elements to I16, then type FF48 into the control and run the VI:
(3,927 Views)
This worked.
But why doesn't I32 show signed integer and I16 does?
(3,908 Views)
Hi sarwat,
Because FF48 (I16) is something completely different than 0000FF48 (I32)…
(3,904 Views)
I need to join multiple elements of an array into a single element.
I've attached a picture of how i want it to be.
How can I do this?
(3,890 Views)
Hi sarwat,
Several options:
  1. Index the elements you  want to join, then use the JoinNumbers function…
  2. Index the elements you want to join and apply basic math to calculate your number (y=256*a+b)…
  3. Use TypeCast…
  4. When your array represent bytes then you might use UnflattenFromString…
(3,887 Views)
You will need the Byte Array To String before the Unflatten From String.  But do note that the Byte Array To String is literally a No Op (takes no clock cycles or memory) since an array of bytes and a string have the exact same data format.
I will also state that I try to avoid the Type Cast and prefer the Unflatten From String due to the additional options with the Unflatten From String.
(3,859 Views)
