convert ascii string to hex string
I'm having trouble converting an ascii string to a hex string and parse.  For example, if the input string is EQ36 (length = 4) the output string should be 45513336 (length 8).  Any suggestions how this conversion can be done?  Thanks in advance.
(9,982 Views)
Hi, this should do it.
Greets, dave
Message Edited by daveTW on 06-30-2008 02:12 PM
Greets, Dave
(9,979 Views)
If it is only a "display-thing", there is an even simpler solution!
Just display the string in a string indicator and set it as "Hex-display"....
hope this helps,
Norbert
Norbert
Expert: Geometry
(9,972 Views)
Thanks a bunch, worked perfectly!
(9,971 Views)
